ecu/ wiring/ knock question
tyhoppy
119
Mar 27, 2006
New Bethlehem, Pennsylvania
Ok. I've had this knock problem for quite a while. and after expending all of my resources I cannot find an answer. The chilton's book says the harness going to the sensor should have 8 - 11 volts. Mine has 5.8 Also, when I check the continuity from the ground on the harness for the sensor and the negative on the battery I get -3.3, I'm not sure if this is good or not. However I believe that it is either in the wiring for the positive to the sensor or the ecu itself. Can anyone guide me on what to do next? Also, would rewiring the sensor from the ecu up help? Any help in finding which wire to tie into would be greatly appreciated, thanks! -Tyler
Can't Anybody Help Me Out Here?
