ecu question
Well it is not the most easy task. you gotta make a harness for the new PCM to fit with the 1g connections. you need to get an OBD2 port as well and wire that in. You're probably gonna want the 2g MAF sensor as well and possibly the knock sensor. Im in the middle of putting an Evo 8 PCM into my talon.
