ECUflash ECU Flash
tyvo98gsx
Feb 10, 2009
New Philadelphi, Ohio
Just posting to see if anyone is in need of help tuning on the black box/ecu flash. I am not claiming to be an expert by any means but I could possibly provide some info. Basically had to learn how to tune this on my own because there is practically zero support and no reputable shop would touch it. I will break down what I have been able to accomplish so far.
Car is a 98 GST
93 pump gas
Full SD conversion
Electronic boost control
FP Green
1200cc injectors
190 pump
Running around 26psi
No oxygen sensors (was having a difficult time getting the ltft dialed in)
-this means car is always in open loop which requires more precision but is doable
No ISC motor (motor went bad and fried that board on my ecu)
-I have been able to get it to idle fairly well
AFR is consistent low 11’s high 10’s no knock
Timing at redline around 15 degrees, peak 9
According to my dragy the car is trapping around 120 so should be making roughly 400hp. Never been on the dyno just street tuned. It runs pretty good. I am sure someone out there could squeeze some more power out of it but the point of this post is to help anyone that may be struggling with this platform.
I don't but I'm sure even a basic walk through of how you tuned yours would be useful to somebody trying to get started.
Sometimes my role is to just move the
Gotcha. I know there are a couple threads on the basics like downloading ceddy mods and what not. I guess this would be aimed at more advanced/nuanced questions.
I was able to do similar things with mine.
I used an aem wideband to simulate the narrow band and was running e85
I was wondering how difficult it would be to switch to E. I know my load is already maxed out so that would be one issue. Other than the fuel system did it require any other changes?
