ecu compatibility
killermind
Aug 21, 2012
Hatillo, Puerto_Rico
I would like to know if the 97 ecu is compatible with a 96 car. the engine is a 420a and is a automatic transmission. thanks in advance:D
While I can't answer the question, I don't deal with 2G's or 420a's but, you could call a dealer and ask them if the part numbers would be the same.
On the older 1G's you could swap about anything in, as long as it was NT or turbo Auto, Manual etc etc.
the part number of the ecu is 5293014, the guy that sold it to me tells me its compatible but I've read otherwise, so I would like to know the answer, thanks guys
he told me there's no difference
I tried it but it doesn't start my car, no spark to the ignition coil
well you can make that ecu work but its alot easier to get the proper one for your car. to fix this you would need the pin lay out to both ecu's and have to switch some of them around to make it get spark,timing, power ect.
here again after a long time...
Im planing on making all the wires on the car new, so I was wondering if anybody here has some tips or the number of the cables used, where can I get them, ect, your help will be great, thank you
PS: bought a 96 eagle talon ecu because it was compatible with my car , we checked the vin number, but It was the same, because of that I'm going to replace all the wires
