ECMlink ECMLink... new injectors... AFRatioEst
white92tsi
48
Mar 15, 2014
De Soto, Kansas
I just installed my 650s... I changed the global fuel settings and dead time as instructed, but AFRatioEst is way off when datalogging. I used the fuel flow factor for afratioest to get it back to where it should be, but I would like to know if there is a better way to tune with larger injectors.
I have a 190 with no afpr if that matters.
Thanks.
Using my wideband is a given. I am switching to SD soon and using my maf to set up the base ve table. I need the airflow to be as accurate as possible. AFRatio off and wideband correct tells me that either I missed some setting or the airflow settings are way off.
As it turns out, the new injectors are spot on because after clearing out the mafcomp sliders, it is almost perfect with no fuel flow adjustment.
Thanks for the comments... and for the link.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
