ECMlink AFRatioEst is flat
Boostdclips99
306
Mar 19, 2006
Roanoke, Virginia
I did a quick change of injectors today, then setup combinedft and airflowperrev. I made a quick 3rd gear pull and noticed AFRatioEst was flat at 9.5. Wideband is reading fairly accurate, I know there is some knock to work on. What could be causing this drastic change? Running v3 SD. Thanks for the help!
AFRatioEst is reading exactly what it should be (since it's basically just reflecting the AFR targets in the DA table).
Please read this.
I'm still getting the hang of SD, so I wasn't sure if the DA tables were needed to be updated with target AFR. I'm using your LinkTools for VE corrections. Do you have any plans to include a DA table scaling option in there, or am I just looking over it?
BTW, you need to get some sleep. LOL
