turtlebain
- 447
- 28
- May 16, 2012
Rochester,
New York
Guys, I got to put in my new EPROM ECU with ECMlink V3 tonight. After I got it to start up, I noticed my idle had changed, and it feels more suitable for the street. However, I have issues. My A/F is way off from what it was previously. From 1,000 to about 3,000 RPM it's showing 17's to 18's. It does drop down some after that, but it doesn't give me any confidence about driving it to work tomorrow.
Fuel Pressure Verified at 42-43
No boost leaks
It needed a tune before, but everything else was working properly.
Injectors: Lucas 1200cc
Global Fuel: -62.5%
Global Deadtime 405 micro seconds
I attached a cruise log. What could be happening?
Also if it was previously wired to use the stock boost gauge as an indicator for knock, would that still be gauging knock with the new setup? The only wiring I changed was swapping the pins 10 and 23 in the ECU.
No boost leaks
Global Fuel: -62.5%
So you mean I have to go back and select the wideband value to be logged. The UEGO has got to be in there as far as type goes..
