ECMlink ECMLink Fuel Adjustments?
Devilsfutbol17
407
48
Jul 27, 2007
Bellingham, Washington
What is the difference between adjusting the Fuel Adjustment Table in the ECU config and adjusting the OpenLoopMaxOct table in the direct access menu?
I see in the OpenLoopMaxOct table that you can adjust it by the load as well, but is that the only difference? Are fuel adjustments made in the Fuel Adjustment Table similar to just making adjustments to the AFRs in the DA table? Thanks
