1G eclipse 1990 1.8L FWD missing bolts
julio cesar
Jun 8, 2020
la paz, South America
hello, i bought a amitsubishi eclipse 1990 1st gen. engine 4G37.
I went to the mechanic to repair a minor fault in the transmission of my car, then the mechanic told me that the screws that fit in a sheet and later in the engine are wrong, since they are loose, since even one of them can be removed With my hand without unscrewing it, I need to know what screw is necessary for each slot of the transmission, mainly in that part that I mention, since the transmission is a little down due to this and is separated by 2 millimiters of the sheet and the start engine does not fit well preventing the car from starting I would appreciate your help, thanks.
Maybe have your mechanic help explain the problem in this post..? “Slot” and “sheet” are terms that aren’t specific enough for folks to understand exactly what situation you’re describing.
Sounds like the starter plate which bolts to the block using two M6 x 1.00mm pitch x 10mm long bolts. Number 15 in the diagram is the starter plate (sheet) and number 16 is the bolt mounting it to the block.
If you need transmission-to-block mounting bolts, they are the same as the 4G63 engine. In that case, refer to: 2G Transmission / tranny bolt size, length, pitch, location, part number and pictures. A 1G would require only (1x) "U" bolt instead of the (2x) indicated for the 2G.
It's really hard to understand what bolts you are missing or what the problem is. Could you provide pictures of your issue or try to make a much shorter problem statement.
Bolts can be found here aa well as many other sites, just do some google searching. Also if your car is auto or manual I dont know if bolts are different but that's something you can research. https://www.extremepsi.com/store/OEM-Transmission-Mounting-Bolt-Kit-Mitsubishi-Eclipse-90-99.html
sry my englsh is bad, rn i dont have a cel phone cuz fall into water y.y, , the bolts or screwa that i need fit in the cover sheet on the flywheel or flexplate....ill try to take pictures.
i think u have the answer ill check this, thx alot.
