ebay o2 housing, which downpipe?
jjrock5
1,854
15
Mar 19, 2006
Around, Connecticut
Yep you'll need to make a custom DP. You could probably buy a megan DP, cut the flange off of it and have a V-band clamp flange welded in it's place. I've actually thought about doing this myself because I could never get a good seal at that gasket until I bought the EBAY Recirc'd Tubular O2 housing.
Yeah I kind of assumed that. But what if the V downpipe costs less than the cost of a flanged manifold?? It sounds more like trouble than just buying the damn mani.
Yep you'll need to make a custom DP. You could probably buy a megan DP, cut the flange off of it and have a V-band clamp flange welded in it's place. I've actually thought about doing this myself because I could never get a good seal at that gasket until I bought the EBAY Recirc O2 housing.
I also got the ebay housing recirc and it seals up fine...idk. Gasket issues? or is it that the flange is warped?
Megan DP and 2g O2 housing = Bad Seal at gasket :notgood:
Megan DP and EBAY Tubular housing = Good Seal at gasket :thumb:
I'm guessing the size differences had something to do with it.
