Ebay Boost Leak Tester
streetdsmpwr
322
3
Oct 13, 2009
Canton, Michigan
Well i think the t-25 inlet is 2.25, correct me if i'm wrong. I recently used my buddys boost leak tester and it had a 2.5 inlet BUT inside the turbo side of the stock intake pipe there is a rubber insert because it looks like they made the pipe too big. I put THAT inside the 2.5 diameter and it worked great. Hope this helps.
You can also push the boot leak tester further onto the turbo. It will clamp to the slightly larger diameter area behind the area the intake clamps on, right up next to the larger part of the compressor housing.
I used a 2.5" coupler on my car to pressure test it when it had the T-25. I use the same pressure tester on my 16g.
It's not hard to make a tester so I hope that one would work. I don't know what it looks like as all of their pictures are broken (red x boxes). As long as it doesn't leak itself and you can pressurize to at least 20 psi on it unless you run higher, go for it if others agree on it.
Buy it. I bought one, works great. I can leak test 20 lbs fine. I waste many trips & time trying to make this from Lowes & Home Depot. Just order it & sit at home & wait.
:thumb:
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
