Ebay Boost Controlers?
This boost controller shouldn't give you problems and should do the job. Just keep in mind on ebay you get what you pay'd for. It might not last long and may not help if you have high boost #'s like above 15psi
i use a vodoo boost controler and its just a ball and spring kind. it works fine and was only 12 dollars to the house
i bought one of these and it is a goofy set up it comes with a check valve that has a tube to the boost controller and a tube to the wastegate. the air is supposed to go through the boost controller to the intake whatever resistance you set it at sends left over air to the wastegate. it doesnt seem like a sure fire way to work. you can also route it normally like any boost controller but then the engraving on the dial is backwards and more boost on the dial will actually give you less. i blew the dial out of mine so i just threw it away and am running a straight line for now. I would reccomend at least a different style but maybe just a good boost controller from a trusted site.:thumb:
I had a voodoo iv hp and i loved it.. got there ball bearing option and all.. Probably wouldn't notice a difference with a standard though
A ball and spring boost controller is a ball and spring boost controller. It either works or doesn't, and I don't see how it wouldn't. The concept is so very simple.
the first one you were looking at should do fine. Just stay away form the MEGA cheap ones on Ebay that look like some jackass made it in his living room. My friend bought one and let me use it but it wouldnt open or whatever and my car went to 26 PSI.....scared the crap outta me. Needless to say after screwing with it and still going to 26PSI we tossed it but that was like the 10 Dollar Ebay one. As said before you get what you pay for and the one you were looking at looks great. Let us know how it turns out because I have been debating buying one like that since I have had bad luck on Ebay before.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
