E85 afr at cruise and idle with dsmlink....should be around 9.85 right?
Gremo87
128
Mar 14, 2013
Decatur, Illinois
I just got a built 94 GSX that I was told needs tuned - I've been doing some reading on the ecmlink wiki and if I'm understanding things right, I should be seeing an AFR of 9.8 - but I'm seeing 14 - 15 at cruise and idle. Way too high for E85 right? Or is the 9.85 figure some base figure that you'd see under other conditions?
I have a ton of reading and learning to do but just wanted to confirm this. I've parked the car until I can get things understood and straightened out.
1 Lambda is always one lambada. Gas and E85 AFR are just different conversions based on burn rate and other factors. Your Wideband is more than likely configured to a Gasoline scale where 14.7:1 is stoich (1 Lambada). Below are some conversions from gas scale to E85 so 14 to 15 puts you around stoich (1 lambada).
Lambda E85 Gas
0.500 4.880 7.350
0.510 4.978 7.497
0.520 5.075 7.644
0.530 5.173 7.791
0.540 5.270 7.938
0.550 5.368 8.085
0.560 5.466 8.232
0.570 5.563 8.379
0.580 5.661 8.526
0.590 5.758 8.673
0.600 5.856 8.820
0.610 5.954 8.967
0.620 6.051 9.114
0.630 6.149 9.261
0.640 6.246 9.408
0.650 6.344 9.555
0.660 6.442 9.702
0.670 6.539 9.849
0.680 6.637 9.996
0.690 6.734 10.143
0.700 6.832 10.290
0.710 6.930 10.437
0.720 7.027 10.584
0.730 7.125 10.731
0.740 7.222 10.878
0.750 7.320 11.025
0.760 7.418 11.172
0.770 7.515 11.319
0.780 7.613 11.466
0.790 7.710 11.613
0.800 7.808 11.760
0.810 7.906 11.907
0.820 8.003 12.054
0.830 8.101 12.201
0.840 8.198 12.348
0.850 8.296 12.495
0.860 8.394 12.642
0.870 8.491 12.789
0.880 8.589 12.936
0.890 8.686 13.083
0.900 8.784 13.230
0.910 8.882 13.377
0.920 8.979 13.524
0.930 9.077 13.671
0.940 9.174 13.818
0.950 9.272 13.965
0.960 9.370 14.112
0.970 9.467 14.259
0.980 9.565 14.406
0.990 9.662 14.553
1.000 9.760 14.700
1.010 9.858 14.847
1.020 9.955 14.994
1.030 10.053 15.141
1.040 10.150 15.288
1.050 10.248 15.435
1.060 10.346 15.582
1.070 10.443 15.729
1.080 10.541 15.876
1.090 10.638 16.023
1.100 10.736 16.170
1.110 10.834 16.317
1.120 10.931 16.464
1.130 11.029 16.611
1.140 11.126 16.758
1.150 11.224 16.905
1.160 11.322 17.052
1.170 11.419 17.199
1.180 11.517 17.346
1.190 11.614 17.493
1.200 11.712 17.640
Ahh, ok that makes sense. Thank you!
So the figures labeled "Idle" - is that what we should shoot for at idle? (The list doesn't look specific to DSM's) Do these figures vary for different types of engines?
I ask about idle because I get a little white smoke that doesn't smell like oil or antifreeze and the seller said it's running lean. (He didn't know how to use Link either)
Like I said I know I have a lot to learn - and I don't expect to be spoon fed everything. Just want to learn as much as I can asap. Thanks again.
Those labels have been removed from the above list to avoid any confusion.
You want the car at 1 lambda for idle.
The figures never change as far as the Air to fuel ratios. No mater what engine you put the fuel into, the fuel will always burn stoich at the given ratio of Air to Fuel.
For tuning advice, use the tuning and engine management forums. Do your reading first, start tuning what you can at idle and post up a log. Be sure to accurately fill out the provided template when requesting log file advice, without it you will not receive any help.
