schumy
- 79
- 0
- Sep 5, 2011
westfield,
Massachusetts
i have a 95 gsx and im running 750cc injectors and its a fresh rebuild i havent been able to drive it cause i have no idea what the afr is i have a wideband gauge and im tuning it with a apexi safc today i just replaced the maf sensor and on the safc no matter if i add air or take it away the voltage on the safc stays the same and the wideband freezes on 19.5 now should i be running rich because of the injectors?? and i just took out the ecu and there is a jet performance chip in it could that be a reason the afrs wont change? thanksss
