- Thread starter
- #151
larryd
- 4,546
- 5
- Nov 26, 2001
Bear,
Delaware
exactly. I mean granted water injetion or propane injection would probably make it easier to tune on pump gas but that wont solve the problem.
Originally posted by 95GST
Just curious Larry did you drive the car on the street with 28 PSI? How did that feel?
The suggestion to "upgrade" to AEM just because you cannot get the DSMLINK fuel trims tuned correctly is totally absurd.
The DSMLINK is by no means holding Larry back, from the log he posted there is no knock on his 28 PSI run and his timing peaked 17 degrees from 6k+ He could have added some timing gradually and pick up some HP. I assume he ran out of time or ran out of runs.
If you have been on the dyno before you'd know you need to let the engine cool a little between runs while you make adjustments, and 1 hour or 2 will easily go by.
Some of you guys should at least read the thread and his log before making guesses that he's getting timing pulled etc... blah blah. If you're going to bench race, at least read the damn posts.![]()
Originally posted by trooth
I haven't done enough reading to be able to tell what all is involved with tuning the CAS for a 1G block. When I checked his car with a timing light, it was set to about 10 degrees. I adjusted it down to 5... yet his DSMlink was still logging around 8-10 degrees of timing, right larry? So I'm not sure what may or may not be setup correctly there - but something is definately amiss.
.. You dont ground the CAS but ground the ECU from controlling the ign timing. Everything need to be referenced to the crank. How does the ECU know where the pistons are at without the CAS if you ground it? So, it's just going to fire the ignition by guessing?Originally posted by jw
Stock intake refers to the intake manifold and nothing else. I have an idea lets drift further off topic!Originally posted by GSTwkd
also they have cams too so I wouldn't call that "stock intake".
Originally posted by SOURCE1064
He plans to swap the gst engine in his new gsx.
Originally posted by herostar
well duh, I'm talking performance... what kind of engine management?
I'm just sitting here wondering how in the world they got 190whp as a base line when the car is only rated at 195 at the crank from the factory to begin with.Originally posted by hose101772
larryd, thumbs up for going for it.Had i known what i really wanted before my parts buying spree,i would have spent the extra dough and went with the l2r.Garrett has the upper hand in design,most know this.why else would the super mitsu's have garrett style exhaust housing?why design when you can copy the best?yes,i know the agp uses mitsu exhaust housing.<---for everyone who's going to talk crap and call me a dumba$$.dude i hope its nothing but a sensor so you can post up some serious numbers for the nay sayers.now-on the 16g responder--did you look at the write up?if you will go back and look at article again,you will notice the dyno sheets are listed as being run on a dynojet 248c.which is a chassis dyno.so there you have it 342whp with a 16g.not shabby by any standards but the garrett tore it a new one.
Hey Larry, by what time do you hope to have everything tranfered over?
