dummy light came on today!
bradselph
Supporting VIP
917
12
Jun 14, 2010
sebring, Florida
was headed to work this morning and i heard a click under the dash and there that light was so i pulled out my scanner after i got home and heres what it says
codes popped
p0442 EVAP Emission control system leak (small)
MIL Status
ON
Freeze frame when it popped was
TROUB CODE
P0442
ENG SPEED
2546 (RPM)
CALC LOAD
19.2(%)
COOLANT
158(*F)
ST FTRM1
4.6(%)
LT FTRM1
-6.3(%)
VEH SPEED
59(MPH)
FUEL SYS 1
CLSD
well thats what my scanner told me so far i have no idea why the light popped on that code because before it was on there but never popped the light but that was like a month ago :ohdamn:
Check your gas cap. Make sure it's tight. Check the seal on it. Replace it if it's dried out. After that if still on check the lines from the tank to the purge valve and to evap can. Check canister for cracks as well.
ROFL forgot about the gas cap thing ima reset it and tighten the cap and go for a drive and then if its still on i will update back
well i reset it without touching the gas cap and did a test drive for about 20 minutes no codes are showing now so idk what it was that set it off :confused:
well i have drove over 100 miles already now.. and no more codes :hmm:
