turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Here's some pics of my long awaited (by me anyway) Dual 255 intank parallel pump setup. I was going to use AN fittings at the tank cover, but it was easier in several ways to just TIG-braze in new "hard lines" and fit aeroquip stuff from there.
I went to the junk yard and found the hanger just sitting on the hood of the only ecluipse there and it was an NT 2g ( i was ready to pull the pump and other parts i was after but they were either laying around the car or gone) and then on the way back in i found a strut tower brace marked "eclipse 95" not sure if it's front or rear (guessing rear) But i'll toss it on tomorro when i i install the dual pump setup.
Right now each pump feeds from a -6 into a home made distribution block ( its ugly cause i didn't want to go to my parent house at 3 am last night to use the mill
the Outlet is also -6 because my fuelab fileter is -6 aong with my rail.. I was actually going to change it all to -8 and use the 6 for the return but they didn't have enough -8 line and i wasn't about to wait to order it, and after a few calls i was assured that one -6 would feed my motor plenty for my goals of low to mid 400's on turbo and then up to 525 on laughing gas (the whole system can easily be upgraded to -8 feed -6 return fi i find that it won't hadn't the power levels, but i doubt that's going to happen really
I also chose the blue "push lock" lines and fittins because it's easier to work with and the line and fittings for it are a bit less expensive
I also noticed that the ID of the blue stuff was larger compared to the black SSbraided stuff when comparing units in the same size designation(i.e. -6 in blue was 10mm ID... the ID on the braided -6 stuff was lucky to push 9,, pulling on the calipers to stretch it) I was also told that I should use it instead when i mentioned running E85, the material is suposedly better suited for running methanol (and other alcohols). I was told the regular braided stuff is said to break down over time where this wont
Right now there's one 255 and one stock pump in it (for mock up and assembly) and it still needs the last wires soldered and insulated and it's ready to go.. Tomorrow i just need to pull my current hanger, swap the 255 from it to this hanger and drop this one in...then it's just a matter of routing the fuel line and trimmming the excess as my filter is already setup with a -6 inlet (Man, 2 wallys is realy gonna make one ewicked "whine" i bet)
I haven't even got it in my car yet and already have requests to buld 2 for local DSM'ers and one for a local guy with a blower powered Ws6 firebird (all wanting to go E85 after seeingthe change itmade in my car too
) One DSM guy paid upfront when i quoted the price on the hanger alone and then said, run the whwole thing to the rail too
Without further procrastination here's da pics!!!!!!! (i'm very rpud of how it came out, and wont' change a thing on the next three that are ordered..plus i can build and sell the whole thing from hanger to rail for about the same as the the onlly dual pump hanger i've been able to find on the net ( and i bet mine won't leak like that aluminum on either
Let me kow what you guys/gals think
)the Outlet is also -6 because my fuelab fileter is -6 aong with my rail.. I was actually going to change it all to -8 and use the 6 for the return but they didn't have enough -8 line and i wasn't about to wait to order it, and after a few calls i was assured that one -6 would feed my motor plenty for my goals of low to mid 400's on turbo and then up to 525 on laughing gas (the whole system can easily be upgraded to -8 feed -6 return fi i find that it won't hadn't the power levels, but i doubt that's going to happen really
)Let me kow what you guys/gals think
Guess it's time to either run a larger return line from the AFPR or see if just opeing the return line in the fuel pump hanger will make any difference...
