dual vavle springs in the way cant torque down head
drfinest1809
Jan 30, 2010
kssimmee, Florida
sorry but i search for it before and found the threads and today i could not find them, but hears my issue i have dual valve springs but im having trouble torquing four of the bolts due to clearance. i even grinned away at the bolt just to get more clearance and im still having issues. Dose any one know what im doing wrong here, i even try pushing the springs to the side a little bit, but there not going anywhere...
can you post a pic? its really hard to help you without a visual,
yeah that happened to me when i was putting mine on. I first put on the washers then started the nuts. then just started tightening them up, the springs will move a little. I never hurt mine to do it this way either. From what i remember it only caught on a couple of them near the outside of the head. Id say just get them started and tighten them down like i did.
lift the head back up off the studs and slide the washers under the spring pads then slide the head back down over the studs
