DSMlink?
importlegions
Oct 8, 2004
catawba, North Carolina
can i use the dsm link with a 95 eprom ecu on a 97-98 eclipse stroked to a 2.3? and if i can what will need to be tuned? it says on the site it will automatically make the 3-d maps for the ecu, so does that mean it will not need to be tuned? thanks for all advice given, u guys rock!!@#
Yes you can use a 95 Eprom in any year 2G. For 97-99 the plug wires will need to be swapped for the firing order to be correct. The size of your motor has no bearing on the ECU whatsoever. DSMlink only affects fuel delivery under WOT, you set global settings for your injectors and the car will drive like normal under regular driving. Honestly it sounds like you need to learn a lot and I would suggest reading as much as you can before you tried to stroke a motor or even get near a car equipped with DSMlink. :thumb:
