dsmlink question
dsmtalontsi95
268
Nov 5, 2007
glenvile, Pennsylvania
I just got dsmlink and installed it on my 97. After installing it I later found out that I need the number on the back of the chip to sign on to link's forums. I have a quick question while I'm at work. Last nigh I noticed that timming was droping to around 8 wile I gave the car a little gas, the car would then would shutter. I don't know why, I was only at 25% throtle. The other question I have is on the ride home lastnight the car started to hesitate (cruising at 45mph), when I got home I poped the hood and the manifold was glowing red. I have a wideaband and it looked fine on the way home. What caused this? How can I hook my wideband to dsmlink so it can help with my loging. On a final note I havn't done the lftl lo and high settings yet since the car is acting up I don't want to go far from the house to cruise at one speed. Any help is greatly appriciated.
glowing read to me means that you had the timing way retarded. I saw this happen once on a 6 bolt swap in a 2g where the kid didn't tighten the sensor down, pulled and retarded the timing and burnt the valves. If your air fuels were fine, which is also odd for glowing read manifold unless u were running wot for a mile or so, then i would start looking at either ignition settings or maybe mechanical engine timing. Now on this 97 does it have a 6 bolt swap? Because that's the only reason i could see a 2g running odd timing, unless the link is set for it of course.
Did you make sure to swap your spark plug wires around?
Do you have "Use non95/96 style cam angle sensor" checked?
Here's some reading on logging a wideband:
installnewsensor [ECMTuning - wiki]
The fuel trim tuning shouldn't affect driveability right now. If all you have adjusted is for your fuel injectors, everything else should be running off the stock maps (fuel, timing, and airflow).
Here's a good guide to get you started:
http://www.dsmtuners.com/forums/articles-tuning-ecu/262460-basic-dsmlink-tuning-guide.html
since it has a 6 bolt swap and your using a 1g CAS i would use the link option to enable the abilty to set mechanical timing on your motor and set it to whatever factory specs are for a 2g using the factory timing cover. Sounds to me like its just retarded ignition timing
Heres a log of a little boost. I'm going out now to see if it's pulling timming again. I'll post up a log as soon as I get back.
see its not bad but what i am very curious about is since your using a 1g CAS did you put the motor in time with a timing light? The ecu will show you a timing value but if your cam sensor isn't in sync with the ecu that value may not be correct but let us know how it goes and keep on :rocks:
I just took the car our for a little spin and noticed that everytime the car started to hesitate the tach would jump. I've already ran into this but I thought we fixed it. I've already changed out the cas, and the coil pack before but I guess that didn't fix the issue. What tells the tach to work? Is there anything else to look for in this problem, I'm starting to think they're connected.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
