dsmlink question
red1993gsallmt
420
3
Dec 30, 2002
long branch, New Jersey
i have a wideband that i use with my datalogger, i remember having to adjust the offset yto make my dattalogger read the same as my wideband gauge. will i have to do the same with dsmlink?
What wideband do you have?
I simulate o2 feedback with ecmlink so I tapped my wideband signal wire into the o2 signal wire on my ecu. It logs fine with no offset needed.
It depends on if the wideband you have is one of the supported widebands in the DSMLink program. If you cannot find a preset in the program that matches your gauge you may utilize a value called "LinearWideband" that you can define and refine to match your gauge. Setting up the Linear value will take a whole total of three minutes.
externalsensorlist [ECMTuning - wiki] a list of supported sensors.
