dsmlink logs, need some advice!
spritian
78
Mar 14, 2011
Murrieta, California
Already posted on ecmlink forums, but figured I'd copy here as well:
So I finally fixed some pre-turbo exhaust leaks, and car seems to be running/boosting much better. A couple things I noticed... my boost seems to be pretty sporatic and falling bad on WOT. I plan on doing a BLT tomorrow to hopefully isolate my boosting problems. Could this be something else or def a boost leak?
On the first log I've got quite a bit of knock at low speeds (>20 mph). Should I be concerned with this and fix the timing tables?
Both logs I followed the fuel trim video, setting my openloop higher so I could get a decent MAFComp layout. The first log had some original tables, and the 2nd log has the first's logs suggestions and smoothed out. On both logs I have a few spikes (500hz and 1200hz), does the smoothing pattern look ok or should I adjust so it's not as drastic?
Another thing I noticed is my CombinedFT is still kinda all over the place +/-4%, even up to +/-8% at times... Should I adjust the deadtime at idle to combat this?
Lastly, on the first log I was able to get 2 really good pulls @ 169secs. My AFR from my LC1 is around 8, which is WAY to rich. I'm supposed to be at 10.5-11 on WOT correct? How do I go about fixing my AFR on WOT?
Sorry for all the questions, just wanna get my shit tuned perfectly
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
