Need Some Advice
afieclipse5124
86
Dec 27, 2004
Chandler, Arizona
I need my hub bearings replaced, but a few shops I called said it would be around 130 to 150 dollars for each wheel. Plus Labor? Is that too much? I can't really afford to pay that right now.... anybody know some cheap but good shops around Chandler?
Well the parts are the expensive part and if the shop uses quality parts then that cost is right. Maybe someone here can recomend somewhere else to get a better deal then take them to the mechanic. I am afraid if you don't do it yourself it's goin to cost you. Even if you do it yourself it's still a pricey fix. How bad is it? I am guessing one or both make noise going around corners. If you push the top of the wheel side to side does it move around? If they don't make noise in a straight line you may be able to hold off for a little while to save up some money.
It hasn't gotten that bad yet, but it does make sound going around corners. I guess I'll just have to wait until I get more money and not use the car so much. Thanks ;)
