DSMlink help!!!
TSIflyer95
217
4
Feb 24, 2011
Columbia, South Carolina
Hey guys. Okay so I got my V3 lite in and have been messing with it some today.
I will admit, I have not done a lot of tuning. I am NOT going for all out power right now though. I am going for a street tune per se.
Here is my deal.
Link does not seem to want to run in closed loop for me. OR I hav issues with the motor. The reason I say this is because my O2 sensor doesn't change voltage. I stay at about .85-.95 all the time. It doesn't cycle like it does in the tutorial videos.
My next thing is my combft does not show up. I have it listed as a desplayed value but I get nothing.
I guess in short I am looking to get a base map set up so I can drive the car.
I was already getting .4-1.4 knock just by revving the motor. I tuned most of that out in the "minOCT" tables in link.
But yeah. I need some help to get the thing at least running right so I can start doing pulls and tune detailed then.
And the motor is a 6 bolt, 1g rods, 2g pistons. I bought it from the guy and he claims that it has BC valvesprings and retainers, and BC272'.
Thanks in advanced.
Okay. I'll try to get that up.
Okay. The log I just made is attatched. That is just cruising through the neighborhood and idling.
The only thing I see that is way different in my log than other is that my timing is stupid retarded. Like 5degrees when others are at like 30 degress???
Some thing is messed up maybe with the boost sensor. the timing is correct for what the ecu is seeing.Its showing like 20psi of boost when your driving around. where do you have the map sensor hooked up?it has to be hooked up on the engine side of the throttle plate.
