DSM Link V2 question
The software isn't system specific. It will work with all versions. IT will ask what setup you are using when you set it up. Everything is free to download on ecmlink's website. Make sure that you get a cable with the setup because they won't sell a cable separately.
I beleave he meant the old V2 cable in that case its 2g's that you have to have the cable
You can use a V3 cable for v2 in a 1g though.....(Not like they advertise it though) Just make sure you get the 1g V2 Memory board or youll be SOL and its more then likely not a real Dsmlink package
As long as you get all the stuff pictured you'll be all set. but make sure you either get the keyspan adaptor with it or you'll have to purchase one seperately.
whats a keyspan adaptor?:hmm:
The Keyspan adapter is used if your laptop does not have a native serial port built in.
Personally I do not like to use adapter and I use the V3 USB Cable.
I have one for sale, If you need it shoot me a PM. Never been used or connected to a laptop/car.
This is the cable.
ECMTuning, Inc.
Personally I got tired of being limited with V2 and upgraded to V3 and it is so much better.
Just a Note
Last time I seen a new Keyspen Usb adapter it was $48
The V3 Cable is only $39 an is just one cable no messing with multiple cables
