Drivetrain problems need help
Talon tsi PR
77
Aug 29, 2007
carolina, Puerto Rico
I have an '91 Eagle Talon tsi AWD when i got it the past owner told me the clutch was slipping so i bought a new clutch kit and a fidanza flywheel but after i mounted everything and drove the car it still feels like its slipping the clutch i already check the transfer case, the rear differential and the transmision gears. But the only thing that i didnt check was the front and center differentials could that be the problem? Please HELP ME
mine would slip when i broke an axle. i didnt know my axle was broken till i got under the car. it felt normal till my turbo spooled then it would "slip". this could be one of your problems. it could not be. check all the axles also. you only checked the trans tcase and diff. if this isnt it then maybe there is something else wrong with your trans.
Good Luck.
