Driver's Side Halfshaft
Jofus
Sep 7, 2007
Richmond, Indiana
I've gotten the passenger side halftshaft out, but the driver's side is giving me fits. Everything I've seen says to pull the support bracket, and I think the nut is a 14 or 15 mm, but just isn't enough room to turn a wrench once I get it on there. Anyone have any hints on removing the bracket? Thanks.
Use a big prybar between the inboard joint and intermediate shaft. Turning the shaft 1/4 turns between prying. The key is to try get the c-clip on the end inboard shaft centered while prying.
So it is just prying the driver's side out, and no removal of that 2 bolt bracket? That would be fairly awesome!
Great! I'll give that a shot. Hopefully that'll give me enough clearance to get the engine out.
