Driver door lock
intimidator2000
166
Sep 16, 2004
O, Florida
I am trying to install an alarm and when I hit the unlock button both door locks unlock. I was wondering if there is a way that when I hit unlock button once it would open the driver side and if I want to I can press the unlock button again it will unlock both doors.
That would be part of the alarm, some have that feature and some don't. Its going to be extra wiring too.
No idea. Every alarm is different. Every car is different.
According to Directed Electronics:
90-91 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser
Factory Alarm Arm N/A
Factory Alarm Disarm Brown/White or Brown/Black (-) Driver Kick Panel Harness From Door.
92-94 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser
No alarm wires listed, but I would test based on the 90-91 wire colors and locations.
95-99
Factory Alarm Arm Green/Yellow (-) Driver Kick Panel Harness From Door.
Factory Alarm Disarm Green/White (-) Driver Kick Panel Harness From Door.
Your aftermarket alarm should have a "Factory Alarm Arm and Factory Alarm Disarm" output, at the very least a disarm output. If it does not, you can just as easily use your door lock/unlock wires to arm and disarm your factory system. This may or may not lock/unlock your doors. If they do not work the locks when arming/disarming, diode isolate the alarm wires from the door lock wires and you shouldn't have a problem.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
