Drive w/o front axles?
TsiTalon90
159
Dec 23, 2002
Granby, Massachusetts
Quick Question guys, it might sound stupid.
I just got the car back together, and did the t-case fix, I need new cv axles and there currently removed. Is it possible to drive the car a short distance wothout the fronts in?
Thanks Josh
it's perfectly fine if you don't mind fluid pouring out of your trans. If you can somehow plug those holes a short distance would be ok but I wouldn't beat on it.
That sounds fun... Almost as fun as me having to drive 2 miles last night in 2nd gear and not being able to stop unless I wanted to turn the car off and put it into gear again (only ran 1 stop sign). Good luck.
