m_0ney_pit
- 819
- 86
- Jan 12, 2007
Easton,
Pennsylvania
So anyway I've been researching alittle about different ways of dealing crank trigger issue with the 6 bolt swap into a 2g and there is the options I have found:
1. Use the black top cas- con is CELs, startup issues
2. Kiggly trigger sensor - con is its expensive, non-replaceable sensor
3. Fabricate your own bracket for the 2g trigger - no cons, just needs work/fabrication
4. Hyundai 96-97 front case - some people say this will work but it looks like the block needs to be tapped for the 1 out of line oil pump bracket bolt and you have to use the hyundai oil pan and OFH
5. Use the RRE og way and mod the 7 bolt front case - not doing this hack job... to much work
Why can't we just use the 7 bolt trigger plate and trigger with a little custom bracket like this wise fellow did?
Project Zero G Forums ~ View topic - "Hidden" 60-1 / 32-1 / etc. Trigger Wheels
