2G Drain lines?
Canatalon
3
Feb 28, 2021
Summerside, PE, Canada
Hey everyone, so I’ve been doing some welding and patching in the back trunk area as rust is coming in through the windows n who who’s where else. Anyways the driver side rear looks to have one drain hose and the passenger side has 2. The one is easy to spot but I loose the other trying to figure out where it is as that could be where more water is coming from. Who’s got the answer?
Thanks!
One is for the sunroof drain, and the other that you're loosing, should attach to the trunk area so that drains. I pulled those all out of my car and had to spend a lot of time unclogging them so they'd work again.
Can any help ID were the drain tubes exit the car ?! I can see in the image and in my own car the passenger rear drain line which exits at the trunk.
But I cannot find the exit for the other 3, im blowing compressed air in the lines and I cannot find were they exit.
Thanks 🙏
When you lift the hatch there is a hole in the quarter panel in the gutter where the hatch rests. That hole just goes directly downward and drains water or rain behind the rear tire behind the bumper. The driver’s side has the same thing and the little tube is tucked behind the antenna mast.
It’s important to clean those drains so that the water doesn’t build up, it can eventually fill the back seat area with water and the hatch
