90laserRSfwd
- 1,411
- 87
- Mar 5, 2007
Elizabethtown,
Pennsylvania
I'd like to start an open discussion, with focus SPECIFICALLY on building a long block (block and head), to utilize the full capabilities of Forced Performances 68hta. It's obvious that the only way to utilize the full potential of the 68hta is going to be excluding the use of pump gas. Ethanol (60% - 98%), Methanol (M1 more then likely), or the higher end of VP, Torco, or Sunoco, etc's racing fuels are going to be the only options.
Keeping the fuel choice in mind, I ASSume, that any compression ratio less then 9:1, wouldn't be utilized.
I'd like to know what everyone else thinks would be the IDEAL build specifically for maxing out the 68hta.
