ENGINE BLEW= Engine BUILD
hey i need to know some things for my build guys
Things i was thinking that i would need and i need your input on if i need something added taken off your guys .02 with machine shops
i was getting
head resurfaced
block bored with molly finish
crank balanced and turned
let me know what else i need im getting new rods and pistons
I would make sure that the shop is using a torque plate when they do the boring because if they dont, there is a good possibility that it will warp the cylinders. Other then that, i wish you goodluck on the build :hellyeah:
hey need some help with the crank and rod bearings im going with acl race bearings whats with the 0.001 for extra oil clearance is this something to get or does it create more problems then it helps? thanks guys
I think the name says it all "race bearings". Careful machine work and special attention to the thrust bearing is really the key. ARPs all around is great insurance, but really careful machine work is the key. A turned crank is good for 400-450 hp no problem. BEK and oil port mod and your good to go, if you have'nt done that already.
