Doubt with wiseco piston rings
talontsiawd08
163
Sep 20, 2012
Chihuahua, Central America
I just bought these pistons are Wiseco, this is the information I have with them ...
They are 6 bolts and 85.5mm (.020 over) and They are 8.3:1CR. this is all the information that I have of them
I would like to know what are the correct piston rings should I buy
some photos of the pistons
Any help will be welcome
Greetings
Just call up wiseco and order a set of rings from them. If you clean the tops of the pistons really well there is usually a number on them. You can give that to wiseco and they will know which rings to send you.
i have a problem man, i am international dsmer, i am from Chihuahua, Chihuahua, Mexico, the call from my country to Wiseco is a rather high cost, the other problem I have is that I can not speak English, I can write but do not speak it
I was thinking of buying these rings but not sure if they are correct...
[ame=http://www.ebay.com/itm/350472927568?_trksid=p2055120.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_1002wt_716]Wiseco Piston Rings 85 5mm DSM EVO Eclipse 4g63 020 20 | eBay[/ame]
Thanks
What is the part number on the pistons?
Post that up, and Myself or someone else will post up the part number you need for rings.
i have a problem man, I'm in Mexico and pistons in El Paso, Tx with my uncle. I wanted to buy rings once to travel to USA for pistons and rings together
Greetings
Unfortunately, i havent the part
number, but I saw this list I
show below and it seems that
all Wiseco pistons with .020
overbore using the part
number 8550XX
