Doubt with 13g hotside
talontsiawd08
163
Sep 20, 2012
Chihuahua, Central America
I have a TD04 turbo from a 1g automatic but has the hotside with cracks, I know it 13g IS TD04 and 14b and 16g are TD05
Can I adapt it another hotside or necessarily has to be the other 13g?
Greetings
Oswald
14b housing is impossible to do fit the TD04
if I can only use a TD04 hotside, What do you recommend to buy for my TD04?
A friend of mine has this
hotside, he says it's TD04
Is this true? If anyone help
identify it would be helpful
Thank you
5cm2 housing from a JDM 13T. It will work with the turbo's center housing, and it will fit a 14B or T25 manifold with the 52mm sealing ring. You should double-check the turbine wheel's spec against the housing before using it, however.
This turbo is in my country but in another state, that's why I wanted to know if it would work on my turbo, then it is almost certain to work with my turbo
Thanks again Justin
i went and pulled my old 13g out of the garage and It looks just like the one from my 13g it has the same markings on the side so i would say yes its a td04.
Thanks Buddy, Muchas gracias por ayudarme
Another question I have is ...
How many psi i can run with that turbo In this hotside?
I mean safe and efficient psi
Greetings
