Double din radio install
Nicg
May 30, 2022
Port orchard, Washington
Can I get any recommendations for double din headunit. Can’t seem to find a proper dash kit or anything. Hoping for some help
It’s all personal preference really. I usually like pioneer head units, but there are lots of good ones out there. You can go into a local Best Buy if you have one in your area and check them out and see what you like best.
I have a pioneer double din. Just cannot seem to find the correct kit anywhere
You dont necessarily need a kit you can use the factory brackets and screw them to your new radio. The only kits you need are for single din and you can still use the factory brackets for those to. If you don't have the factory brackets you can modify a single din kit and just use those plastic brackets they come with. You also will more than likely have to shave the radio bezel down to fit it around the radio.
Okay thank you so much for the help guys. I’ll try it this weekend
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
