93ETGOCART
- 482
- 0
- Aug 28, 2008
stotts city,
Missouri
ok so im wondering what is the lightest door, gutted stocks, tubing and sheet metal, fiberglass, or cf? or any other options that might be lighter. for a 1g by the way
A .125" thick lexan/polycarbonate 1G door window weighs roughly 3.5 lbs. The factory glass weighs 8.5 lbs.how much does the lexan weight?
I honestly don't think you can remove the beam with hacking up the inner shell a little bit. Freeing the beam from it's fixture is the easy part - fishing it out from the inside of the door is the tricky part. I have to remove pretty much everything on my doors to get the job done.has anybody cut out the safety beam with out cutting the inner shell?
