spyder weight?
bigdoug3022
111
Feb 20, 2008
bergenfield, New Jersey
hey guys trying to find out how muich my 97 gst spyder weighs. i want to order a roll bar but i need to know how much it weighs before i chose what diameter steel tube i need. thanks
My mind is a bit foggy but I think stock weight is anywhere from 3100-3300lbs.
thanks man yea thats what i figured, but not completely sure because if it weighs 3500 or more i need to get the 2.00x1.20 ERW.
I'm pretty sure the Spyder tips the scales over AWD. They are quite heavy, so much so that they have stiffer springs in the back to compensate for the extra weight. Either way I'd say 3200 is a safe estimate.
my Manuel says 99 eclipse spyder 4,079 lbs 1,850 kg sounds like alot more than all the ^ LOL maybe im reading it wrong.
something in your manual is wrong.. There is no way in hell I removed 800 pounds by removing the ac components and ADDING AWD!! Just saying.. Id say somewhere around 3000-3100 lbs.. ~~
Keep in mind that there is a difference between Gross Weight and Curb Weight.
Here is an explanation right out of Wiki.
(The difference between gross weight and curb weight is the total passenger and cargo weight capacity of the vehicle. For example, a pickup truck with a curb weight of 4,500 pounds (2,041 kg) might have a cargo capacity of 2,000 pounds (907 kg), meaning it can have a gross weight of 6,500 pounds (2,948 kg) when fully loaded.)
As I recall my 97 Spyder only weighs "Curb Weight" around 129 pounds more than my 95 GS.
I'll try to look up those weights again.
BK85
Ok update: The Spyder GS 2888 Pounds Manual Tranny / 2943 Auto and the GST 3053 Pounds Manual Tranny / 3142 Auto.
This is from the DSM "1,000 AAQ" http://members.shaw.ca/costall/1000Q/answers-specifications.htm
BK85
This is from the DSM "1,000 AAQ" 1000 AAQ - DSM factory specifications
Wow according to this chart the Spyder only weighs 46 pounds more than the coupe:hmm:
BK85
does anyone know if there are any companies that make a roll bar for the spyder. i placed an order with autopower, but got an email saying they dont make one for the spyder. womp womp
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
