door install/blinkers
Glliw
471
3
Dec 18, 2005
Panama City Beach, Florida
So, just got a enw eclipse but it needed a new door and the blinkers don't work.
I need help on how to get the door to go back in there as easy as possible since it is like 100lbs. :mad:
Also, the blinkers don't work. Is there a vfaq that I don't know about for this or some help?
when I have put doors in before I have done them by myself and I would set the door up the hinge and use a screw driver or something like that drop it in the bolt holes to help hold it and then on the other side I used a jack, I had old ass carpet rolled it up set it under the door edge and used it to jack the door up until I got it close and went from there.
I got the door on, only to realize that the lower hinge is whats failing and need to replace that. Two floor jacks, a jack stand and some spare plywood worked wonders.
BUt about the turn signals, is the fuse under the dash?
do you have a haynes ro chiltons book, it should point you inthe right direction or just call the local mitsu dealer and ask the service dept. that should do it.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
