Done the searches read faq but i still need a answer
skywarp
30
Mar 15, 2004
Las Cruces, New Mexico
Okay,
Ive done all the searches , read every faq, but i still a little shady on where the boost gauge taps into. I have a 98 eclipse spyder gst, and So far ive read 3 different places where to tap into. Ive already ran and mounted the gauge, i just need to connect the "T"
to the right hose.
Can some one tell me where is the best place, and a detailed pic of which hose it is, because when i went to look under my hood, there are plenty of hoses in that area.
and the last thing i want to do is mess anything up. i guess im just a little worried about getting the wrong hose cut.. :(
thanks
Rudy
you can unlug the vac lines from the solenoid furthest to the drivers side, and, put your "T" in its place... that way you dont have to cut any lines (leave electrical connector plugged in). Or, if you don't want to eliminate the solenoid, cut the line... but, that is the line you use.
oh btw that solenoid thing is the furthest part of the drivers side firewall, right near the top of the firewall, next to the cluch master cylinder. have fun, boost guages are swell :thumb:
Cool,
thanks guys !!!!!! :thumb:
Ive got another question on the oil pressure gauge( Electrical ),
cant i just hook up the wire to the original sending unit already on the car?
Thanks agian
Rudy
