2G Dome light wiring
Bedicine
542
192
Jan 3, 2022
Toronto, ON, Canada
Hello
I’ve got two dome
Lights but neither match the connector plug in my 2g which was originally from a 97 eagle talon tsi
Does anyone know the correct wiring and I can just change to different connectors for now
The manual shows different connectors for vehicles with and without a sunroof. These are shown as looking at the wire side of the vehicle harness connector, locking mechanism on top.
With Sunroof
E-02
xx
[1][2]
[3][4]​
1 - black, ground
2 - black with blue stripe, to pin 3 of ETACS
3 - black with white stripe, top pin 4 of ETACS
4 - No wire
Without Sunroof
E-04
xx
[1][2][3]​
1 - black, ground
2 - black with white stripe, top pin 4 of ETACS
3 - black with blue stripe, to pin 3 of ETACS
So, yes, swapping connectors around to match what you have can be done.
Thank you for that, what about the wires on the dome light themselves. i have a red/black, red/green and a two greys that are tied together
The diagram doesn’t specify what each is inside the dome light. But it would make sense that the two greys tied together are pin 1 and then share a common ground for the bulbs.
