DOHC head angles...
AllanL
274
25
Apr 24, 2008
LV, Nevada
searched but couldn't find good information...
hoping for anyone's help...
thanks...
If i had the proper tool to get such a measurement i would as i have a spare head at home.
Thats a new question!
Should be able to figured out with a protractor.
I have a head laying around, I will try to make time later today to measuser it for you.
IF you want to make a spring compressor than go to harbor freight and buy a big c clamp and cut a slot in a deep well 1/2 inch socket. It's cheap and works well.
was thinking along something like this:
finally got around to measuring this angle...
60deg from horizontal, give or take a few degrees...
Are you sure about that? If memory serves me correct I would put it well under 45*, maybe more like 30ish*. Or did you mean 60* from the horizontal?
This is what I found, don't know how reliable the poster is, but it came from a thread on this site.
The valve angles are aprox 28' per side int and exh for the 4g63
