Does this ecu look dead/damaged?
1G Eclipse94928
656
7
Apr 3, 2013
Rohnert Park, California
just looking for peoples opinions on if this is why my car wont start/run. I changed my spark plugs, wires, coil pack, and power transistor already so I'm now at the ecu, so i uninstalled it and i can see some corrosion. car will turn over and is getting fuel and would maybe start for a second then stumble and die right away, i was driving, came up to a stop sign, then it just died. i thought i ran it out of gas at first, because it just died after driving normally but i put more gas in and it wasn't that. :/ so i checked the spark and wasnt getting spark in cyl 2 and 3 and still am not after all them parts!! heres some pictures of the ecu. :banghead:
E: dont want to have to buy a new ecu, if i dont have too, and dsmlink seems like there going on vacation for a week or something and there doing orders(or atleast not as fast.) right now, but i emailed them too.
Still sounds like a transistor to me. If you are sure it was a good transistor, check the wiring for it. It is still a possibility that your ecm is bad. It looks like a burnt spot on the circuit board, but its hard to tell.
Your ECU is in definite need of repair as it has quite a bit of damage from electrolyte leaking from the caps. It looks like it has already been fixed once by the pic due to the tantalum capacitor that was added . Wait for ECMTuning to get back with you if you don't want to buy a good ECU , and have it professionally repaired and tested.
Acetone will scrub away the corrosion off the momboard, but the caps will definitely have to be replaced.
A repair bill for cap replacement is tons cheaper than a rebuilt ECU ...
thank you guys they got back to me, and your all correct. going to ship it to them asap.
