2G Does my engine sound ok?
Create a profile with your setup. Engine sounds lopey, which might be cams. Could have an exhaust leak? The apparent uneven idle could be from your setup or from a problem. Without better quality audio and more information about your build it will be impossible to give you an accurate answer or diagnostics direction.
