Does anyone know where the fuel return line connects with the fuel tank?
njdaewoo
167
Oct 19, 2009
Piscataway, New Jersey
Hello everyone, can someone tell me where the fuel return line connects with the fuel tank on a 95 gst? Im doing my fuel line upgrade with the stm 6an fuel line kit( boy do we need to make a sticky for this - the kit is not complete in the fuel tank area. The 6an STM line and the stock tank steel line are not the correct fittings for a proper connection:nono:). I will be doing a write up for the parts I bought for this.:hellyeah:
The fuel return line connects on top of the fuel pump sending unit assembly. You can see it if you unscrew the 4 screws holding the tank cover on under the rear seat. It is a small black rubber hose that it connects to.
You were a bit unclear, but I assume you have the STM Fuel Return Kit. I checked out the STM kit and the return line is meant to go from the fuel rail, to the fuel pressure regulator and then a rubber line connects it where the return line is under the hood. This is easiest so you don't have to run an entirely new line all the way back to the tank.
If you also bought the STM tank to rail kit, then the -6an fitting they give you to attach to the fitting off the sending unit assembly may look wrong; because it is. But the fitting will work, many people including myself have screwed a -6an fitting on there without any leaks. I was skeptical at first, but it won't leak.
    • george bromwell
    • pma1123
    • Sdcryan1
