Does anybody make a replacement for the lower shock mount bushing?
halffast1g
178
Jul 11, 2008
phoenix, Arizona
It is the rubber insert that goes in the bottom of the shock. Mine was all cracked and ate up when I pulled it off my car and needed a replacement without buying a brand new shock
I have a 91 eagle talon tsi awd
Also try napa, autozone, or any other autoparts store. Just measure the bottom and go ask. I've had to replace them after my dad messed them up during install before.
I found some part numbers for the bushings i believe. They are on best valueautoparts.com. It shows for a 93 rear but should be the same, I think you need to order (1) 45g15398 and (1)45g15404. Hope those are what you need. I'm still doing some research for you.:talon:
