Lower control arm bushing replacement?
nahtan124578
Nov 18, 2004
cottage grove, Minnesota
I just got a 92 GSX and it needed new front wheel bearings and drivers side front axle while replacing these i replaced the tie rod ends and lower ball joints also because they were a little worn out. I know i need an allignment because of the tie rod ends but i wanted to know if the lower control arm bushings being worn would affect the allignment and if i should replace them before i have it alligned. I would also like too know how hard the bushings are to replace because i will be replacing them no matter what i would just like to wait till it is warm outside.
Yes it will afftect the alighnment. Just hope your contol arms are not rusted out under the bushings like mine are and need to replace the whole arm.
This is almost a forgone conclusion for anyone in the salt belt just like the fuel pump assemblies rusting. The rear shafts on the lower control arms rust and crumble inside the bushing. The guy that wrote the VFAQ noted the problem but didn't realize that it would cause the control arm to move around more under load since it now slops around inside the new bushing.
Steve
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
