Do I need these?
99Dodge1500
31
Nov 9, 2008
DeKalb, Illinois
I have a 96 Eagle Talon TSi AWD, I have a Pacesetter header, no cat, and I want to set my stock boost up to 14lbs. Do I need to get anything for just this? I am getting GlowShift boost, air/fuel, and don't know what else.
If you start playing with your boost level I would at least get a 190lph fuel pump. Also, the narrow band AFR gauges are basically only good for a light show. I have one just to fill the hole in my gauge pod until I can get something different.
On the T-25 (Stock Turbo) you will not need a 190lph fuel pump. That turbo doesn't move nearly enough air to require more fuel. The most a T-25 will put out is about 10-12psi (at redline(20psi spikes don't count, sorry)). If it is a larger turbo, then you have quite a few things you'll need to buy, most of which are listed Here
You think I need a bigger fuel pump for just two more pounds? How many liters per hour(lph) is the stock fuel pump?
Just port your stock manifold, theres lots of people on here making over 400hp on the 2G ported manifold. While your at it you could port your 02 housing also.
Thanks guys, I have to do the normal tune up, porting sounds like a good idea, what do Iport on the o2 housing? I will be getting a K&N.
what type of t28 is it, just a regular t28 or a big t28 if you get the big t28 your gonna wanna get a larger fuel pump at least the 190 and look into getting a fpr and the more you do to the car the more your gonna have to upgrade, later on injectors, fuel management probably a safc, your gonna need more than just that air fuel gauge, at least an egt gauge. check out other people with similar mods as you and ask them what there running for fuel management.
Thanks, I won't use the pacesetters, I will just port the 2gs, I was thinking a small T-28, Why would I need a egt for? Defiant I know I posted two I didn't know how to merge it or to delete the other one. Sorry
Dodge.... you need to search and learn before you start messing with your car. It took me a year before i finally decieded to go bigger on my turbo. Now i no what im doing and have just purchased a front mount, adn will be ordering a bigger pump and injectors in the next month or so. JUST READ AND LEARN ALL YOU CAN BEFORE YOU START MESSING WITH YOUR CAR.
Yeah I have to wait until I get the money, so I will be waiting until I do regular maintenance, before I hop up. Thanks for the info I will be reading up.
