Do I have to have 2g maf #609?
chicagoavenger
981
13
Aug 17, 2004
Rio rancho, New Mexico
Well I installed a 2g mas into my 1g and noticed that the car will start with the plug connected or disconnected. If I have the car running and unplug the mas it will just rev up to about 3k and if I give it gas it dies out. The only times I get a code is if I unplug the mas and I get 3 error codes on my logger. I thought the car should not start with the mas unplugged or should die if you unplug it while running? Can someone please clarify. Also do I have to have mas #609? I got my mas from a mighty max or something like that and I wired everything up correctly using this
http://www.dsmtuners.com/forums/showthread.php?t=248732&highlight=2g+mas
Pin 1 on the 2G connector goes to the green/red wire that was pin 4 on the 1G harness.
Pin 2 on the 2G connector goes to the green/yellow wire that was pin 7 on the 1G harness.
Pin 3 on the 2G connector goes to the green/blue wire that was pin 2 on the 1G harness.
Pin 4 on the 2G connector goes to the red wire that was pin 3 on the 1G harness.
Pin 5 on the 2G connector goes to the green/black wire that was pin 6 on the 1G harness.
Pin 6 on the 2G connector goes to the green/orange wire that was pin 8 on the 1G harness.
Pin 7 on the 2G connector goes to the green/white wire that was pin 1 on the 1G harness.
Pin 8 on the 2G connector has nothing.
Yea you have the right maf. Any 2g maf works. Some have a little plastic covering some of the honey comb, all you do is cut this out for a little more flow.
Yeah we had to take that off I know what your talking about, cool I just wanted to double check thanks guys :thumb:
