Digimoto or not?
Mikes879
Aug 12, 2003
I just bought the digimoto logging software to run with the safc2 please everyone who reads this let me know what u think of it or if you've heard good things or not., i havent' had a chance to run it yet cause car is still being put together@! LOL
so just let me know i want some feed back
thanks!
Sorry buddy, I'm looking at the digimoto also to tune my s-afcII, please someone help us brothers out.
i use it and love it .. the quarter mile test and dyno things are bullshit and aren't accurate at all if u get them working .. i like the real time sensor view for doing your low settings because u can set the short/long term fuel trims and watch them and it makes it easy .. the datalogging feature is good for 3rd gear pulls but i wish it just saved more data faster .. it is good .. just remember you have to import your datalog into excel as comma delimited so you can view it overall i think it was worth the money
Fmstrat said:
What kind of sampling rate do you get? I just picked one up, and I'm only getting like 2 samples max per second on a 97 GST.
about the same .. i just switched over to dsmlink enough said .. digimoto was good for what its worth tho
You can't log with only 2 samples per second. You won't capture enough data. I get 17-18 on my pocketlogger and 99gst. I can still get 11-12 on other 97 and 98 eclipse with the pocketlogger.
will the digimoto give me enough to get some basic tuning done with my timing, and a/f mix using my afcII
At 2 samples a second, I'd probably say no. You could probably tune low safc looking at fuel trims changing. But when it comes to real logging wot runs, you want to capture as much data as possible, and 2 samples per second would not cut it.
How much are people paying for this digimoto. Is it free? Cause if it isn't, take that money and put it towards a pocketlogger or something useful.
anyone else using digimoto and getting more than 2 sample per second. Also how well does it work at giving you trouble codes.
I've already sent an email to return mine. Either I got a bum unit, or it just isn't all that compatable with my car. I tried it on my G/F's 2G N/A, and got the same results, 2 samples per second max. This is nowhere near enough to see if there is a dip in timing IMO.
